designer82
- Boston
A large textile mill facility has a problem where the kW's coming in from the utility are double what is being distributed at the loads.
About 1,300 kW's coming in from the utility and about 650 kW's being measured as distributed (via individual branch meters to each utilization branch).
Also their power factor is terrible, about .68
They would like a power flow analysis to see where all the kW's are going.
My thought is gather all cable size/length info from utility transformer all the way to all branches and loads. Have an electrician measure kW's at all utilization branches, downstream & upstream of utility xfmr. Also gather as much specific load info as possible.
Enter all that info in ETAP and run the power flow calculation to try and identify any electrical system inefficiencies.
How would you do it?
