James M. Clarke
- Charleston, SC
I have read many of this forum's members various opinions about the appropriate way to show circuiting on a power plan or lighting plan contract drawing. My question is this, 90% of the time the existing projects I review show the typical receptacle to receptacle loops, the homeruns with the panel and circuit number and the tic marks denoting the ground, neutral and hot wires in the run. The other 10% simply show the outlets on the floor plan and put the panel number and circuit number in the middle of the room or rooms the circuit will serve and assume the EC will wire it as best as possible (and probably will).
So, now I have a job to do for the air force and the 65% submittal is requesting circuiting on the power plan. In your opinion, does this mean the drawing can be done either of the ways listed above or does it mean the old loop, homerun and tic mark style.
Secondly, the project my firm is inheriting already has the plan drawn out like the 10% mentioned above but it distributes the outlets in various rooms in some cases erratically (I suppose this was done to eliminate breakers tripping when a meeting is held in one of the conference rooms with lots of equipment). It was difficult to trace out because it lacked the typical loops from outlet to outlet and I was concerned the the EC might miss some of the outlets that were far from the majority cluster or might take the easy way out and wire all the outlets in a medium sized room to one circuit and not alternate three circuits as shown.
Is there a right or wrong way to do this type of diagram or is it is simply a matter of personal preference. Please voice your opinion either way. Thanks
