gar
- Ann Arbor, Michigan
- EE
230228-0824 EST
My power has been off for a week now. No information on the origin of the problem. A line is down several doors from me. No effort to do anything about this line. Thus, there is some greater problem closer to or at the substation.
I am on a delta distribution source, however, at the sub-station it is probably fed from a wye secondary source. My 240 V line-to-line is presently generally reading 40 to 80 V. I did not take look at all the homes on my block, but I don't believe any had substantial power other than the 3 or 4 of us with generators. There are about 28 homes on my block. The time to restore my power seems to imply a transformer problem. Anyone on my block can afford to have their own generator.
Very many common electrical customers seem to think there should never be a power outage, and take their anger out on DTE. I believe DTE had about 400,000 customers without power, and now they are down to possibly 50,000.
It is my opinion that many more people should have some limited amount of backup power available for emergencies. This may be even more important in the future. The power grid is too easily disrupted if an enemy decides to cause us problems. This also means one needs a fair amount of on site energy storage. Getting a lot of distributed solar and wind generation spacially distributed is needed to protect our country.
I have found my 5 kW generator to be sufficient for my emergency purposes. But I would prefer an 1800 RPM unit, and a 10 to 15 gallon tank in place of the 5 gallon unit. If you do not have natural gas available, then you are in big trouble from a cost perspective, and are in a north area. So my cost per day using the generator is about $ 40 to 50 for moderately low electrical usage.
