I was called to check the quality of a household circuit. Here is the problem homeowner has: About once every 2-3 weeks their above range microwave oven will just stop during heating operation and then clock on it needs to be reset. Then it works fine for a few weeks. The owner discovered that the symptom is the same as if you unplug and plug in microwave during operation, ie: microwave stops and clock needs to be reset. GE repair tells owner that problem is with homes power circuit.
I checked that all terminations are tight at the receptacle and at breaker in the panel. Also I verified that the microwave is on its own dedicated circuit and that the cable run from the receptacle to the panel is unbroken, ie: no junction boxes along the way. The microwqve breaker has never tripped. Wire is copper. When plugging in microwave, the plug goes in tight, it does not seem loose at all. The home was built around 1970 and the microwave circuit was added around 1990.
The microwave worked fine for me several times. I heated a cold container of water on high until it boiled. One odd thing that could just be a coincidence is that owner notice it only happens in the morning when it gets its first use of the day.
Is there something else I can test or do for debug?
