I'd like to get the opinions of Electrical Contractors on ideal locations of power packs for lighting control systems such as Acuity Brands' nLight systems, Lutron Vive systems, etc.
In your opinions, is it better to have the power packs distributed in the area of the controlled lights or is it better to have the power packs centralized in one or more locations?
For example, say I have a small facility with ten offices and each office requires a 0-10V dimming power pack. In each of the ten offices, there is a manual low voltage (24V) switch for ON/OFF/RAISE/LOWER, a 24V occupancy sensor, and a 24V photosensor. Would it be better to:
I can see benefits to both methods but am leaning towards #2, mostly because it would likely use less line voltage wiring, the 24V wiring would not require conduit, and the power packs are all easily accessible without having to hunt for them above ceilings.
Thank you all in advance for entertaining this post.
Jason Rohe, P.E.
- Put one power pack above the ceiling in each office? This would cause the line voltage unswitched wiring to be run to each office, would result in relatively short switch legs, and result in short low voltage wiring runs. Or,
- Put all ten power packs in an electrical room, adjacent to the associated panelboard? This would cause the line voltage unswitched wiring to be short, would result in longer switchlegs, and result in longer low voltage wiring runs.
Jason Rohe, P.E.
