Is a power strip considered a multioutlet assembly? If yes, then it looks like NYC does not permit these.
I can't find relocatable power strip in the definitions.
But reading multioutlet assembly definition, why wouldn't a power strip fall into that category?
That basically is the difference, but the definition doesn't contain the words fixed or portable either. :blink:Because a multi-outlet assembly is fixed, not portable.
Informational note is fine IMO - as the NEC doesn't use the term relocatable power taps so why add a definition for some term if the document is not going to use the term?Well I would argue that fixed isn't in the definition. But, it looks like the definition of multioutlet assembly in the 2014 NEC has an informational note that says "power strips or plug strips are not multioutlet assemblies but are relocatable power taps." They should add relocated power taps to the definitions too just for clarify.
I am looking at the 2011 NYC code, where does it say this.
I only see this amendment:
Subsection 380.2(B)(7) – Add a new subsection 380.2(B)(7) to read as follows:
(7) Where cord and plug connected unless listed for the purpose.
But another question, can a power strip be considered a nonmetallic extension in article 382? These aren't permitted in NYC.
Thanks I just did. While it doesn't answer my question if a power strip can be considered a nonmetallic extension from NEC article 382, it does answer a lot of questions I have.
Mainly,
"Relocatable power taps are not intended to be permanently secured tobuilding structures, tables, work benches or similar structures, nor are they intended to be used as a substitute for fixed wiring. The cords of relocatable power taps are not intended to be routed through walls, windows, ceilings, floors or similar openings of buildings."
Mainly,
"Relocatable power taps are not intended to be permanently secured tobuilding structures, tables, work benches or similar structures, nor are they intended to be used as a substitute for fixed wiring. ..."
This is also the reason that most strips have keyhole slots in the back for screw mounting to wall or counter. Those are not permanent either since you can easily remove it without needing tools. There is no requirement to remove the screws too.To me, if your strips were held by Velcro, I'd say it is not "permanently secured". One can't easily defeat zip ties without some kind of tool.
Tapatalk
