Thanks
And the need to know is specifically the reason for the question. I guess the mfg should be able to give an answer as to wither a power supply is or is not hinherintly protected, but that is not always the easiest path.
Tables 11(A) and 11(B)
For listing purposes, Table 11(A) and Table 11(B) provide
the required power source limitations for Class 2 and
Class 3 power sources. Table 11(A) applies for alternatingcurrent
sources, and Table 11(B) applies for direct-current
sources.
The power for Class 2 and Class 3 circuits shall be
either (1) inherently limited, requiring no overcurrent protection,
or (2) not inherently limited, requiring a combination
of power source and overcurrent protection. Power
sources designed for interconnection shall be listed for the
purpose.
This is the question, if the supply is not marked how do you know???
Charlie
