Re: Power surge
And in a typical home with mom,dad,2 1/2 kids and a dog.We likely have several loads,maybe 3 tv's ,sterio,frig,ceiling fans.The chances of it being perfectly balanced are slim but 40% and 60% are within reason.Should the neutral come loose we would see some dimming and flashes but most everything could tolerate this for a while.Hopefully they notice and call sparky.Now if they just let it go because money is tight, then sometime within a few days (or sooner)the system will get too far unbalanced and stuff starts burning.
Think of this as a possibility.
1.Family functioning about normal at 5 pm,typical loads.Neutral opens
2.Kids go to bed and computers,tv,lights,turned off.Now maybe tv in living room on and dads on computer,and a few lights.We might still be somewhat balanced.
3.Hour later parents go to bed.
Load now might only be a few night lights 7 watters.Load almost nothing (we won't get into the ground rods helping )
4.At 11:43 the fridge tries to come on.With neutral open it instantly burns night lights out.With no complete circuit it doesn't run ,but also won't burn up.We now have 2 loads fridge and 1 night light on 1 leg and nothing on other leg.
5.In morning when they wake up late because alarm clock fried,they reach over and turn lamp on.Dam there goes another bulb.
Your now are about to burn up things one by one.
At the panel on leg (a) is a fridge thats been ready to start for hours and on leg (b)we start getting loads that burn up instantly,and reopen the circuit.
My point here is if everything came back on at same split second there would be no problem,but that's not likely how it will go.
On a test board this looks easy,2 resisters ,1 burns open the no current thru either.
Most of the calls i get over neutrals have already taken some things out.If they were lucky they lost a few bulbs,and some cheap stuff.Some have fuses internal and saves the item.
[ February 18, 2004, 02:15 PM: Message edited by: jimwalker ]
