Ranger86
- Las Vegas, NV
There is a new above ground gasoline tank being added to an existing gas station.
Is there a separation distance requirement between the above ground power conduits and the fuel pipes? The plan is to use the same unistrut for both the fuel lines and power conduit with a 12" separation between the two.
I found the 12" separation requirement in the NESC-C2 code page "V" but it looks like it applies to underground lines. Do you know of other above ground separation requirements?
