There is a citation of an NFPA 99 requirement as a note to the NEC article. That would give you the details. But as I read the NEC, IF the building has a door that is intended to be used for emergency egress, and IF that door's opening function is controlled by an electrical operator, THEN the power supply is required to be on the life safety branch.
