Powerfactor meter
what instrument do you use to measure power factor? any advise on brands?
It really depends on the application. Here are some I use:
Switchboard panel meters:
Crompton
Satec (sp?)
Yokogawa
For Testing
Dranetz PX5
Tectronix isolated 2 channel scope
If all you want is a portable pf meter - I'm clueless on that.
cf
Note that if you want to measure PF less than 0.50, extra care should be taken. This is also the issue if harmonics are present.
The selected meter depends on the needs and budget, starting from few hundred dollars (panel mounted, low cost meter) to more than 10k for high quality portable power quality analyzer.
