janasamara
- Portugal
Hi ,
I am a trying to configure powerflex 755 to work a close loop , but I´m have trouble with autotune rotine. When I choose the rotate tune , the test starts normally and performs the static test successfully. Then when it is going to realize the moviment of the axis occurs the following error : Number 79 ( Excessive Load).
If I try to work without performing this test another error appears : error number 7 (motor overload) and the engine does not respond to speed programs very well.
I tried to find in the rockwell manual some information on why this error occurred in autotune but I did not succeed and I believe that for the drive to work properly in closed loop I have to perform the autotune correctly.
I do not know what to do. Is it a misconfigurate parameter ?
Please can anyone help me ?
Thank you
Thank you
