greenspark1
- New England
Hi,
I'm involved in a new small grocery store with a couple of check-out counters. These seem to be a pain to get power/network to since there is no easy way to run conduit to them. I'd like to see if you all have any good ideas?
The owner is proposing busting up the concrete and running underneath in PVC, but this will be expensive and the PVC has to be at least 4" deep. Also you are quite fixed in the location of the counters- no moving/adjusting them at a later date.
I've seen stores use service/power poles such as this: http://www.grainger.com/product/HUBBELL-WIRING-DEVICE-KELLEMS-Service-Pole-4WX77?s_pp=false
They come down from the ceiling and can also be used to mount monitors and other devices on. They don't look the best but are quick easy and able to be relocated if the setup changes.
Any other suggestions/ideas that you've seen work well?
