the_meter413
New member
- Seattle
This is a naive question, but it's driving me nuts: what's the strategy for powering multiple LED strips in coves in a residential install? Here's an example of what I'm referring to; this is just a random picture that came up when I googled "LED cove lighting":
The best I can figure is that there are two approaches:
Which is the more common approach? I'm sort of assuming that the approach would be the same for new work as it would be for a remodel, but perhaps that's a bad assumption?
For reference, the type of LED strips I'm referring to are the 5-meter 5050 type - typical specs are about 6A/72W per 5-m reel.
- Bring mains power to the cove itself; hide outlets every ~12' or so within the cove to allow for plugging in multiple transformers/power supplies around the perimeter of the room. If this is the case, then the designer/builder/carpenter needs to accommodate the bulky power supplies and the associated wiring and receptacle boxes in his/her cove design.
- Hide a larger transformer somewhere more convenient (e.g. in a panel in another room; in a cabinet; etc.), and run low-voltage wiring to the cove. The cove design could perhaps be more streamlined in this case.
