Tinkerer
- Virginia
- Master Electrician and licensed contractor: mostly retired
Recently, I have been installing a lot of landscape lighting for folks who have bought their lights (typically Malibu) from the nearby discount hardware chain.  I am OK with this, since I don't mark up my own supplies very much, I don't need to get involved with the artistic side of the selection process, and I don't need to warantee the fixtures.
I don't think much of the method Malibu recommends in their instructions, with screw together connector boxs, landscape wire that costs as much as UF, and an expensive outside transformer that has a lot of unnecessary complicated features the customer doesn't need. Malibu says burial of the cable is optional, but should be LESS than 6 inches deep.
My experience with my own outside lighting, is that every time I plant something near it, it gets cut, so this is my ideal installation: Run the lights in PVC pipe, buried MORE than 6" deep. with something like THHW inside, no ground, and run the pipe right into the lights. The transformer would be a simple indoor type, mounted indoors. This would be a Chapter 3 wiring method which would be acceptable to the NEC for outside, inside, and concealed applications (see I read the other posts about this subject). I have used "T" type conduit bodies to "T" up to each light, but I believe this is unacceptable because of article 314.29, requiring conduit bodies to be accessible. My questions are these:
1) Is there a PVC conduit body that allows two pipes to be stubbed up, and connected to the fixture? This would be something like a tiny box that wouldn't look bad with some mulch pushed up against it.
2) Does anyone have another clever, attractive way to run pipe directly to the fixtures.
3) Here is the philosophical question: Why exactly did the industry settle on 12V for low voltage lighting? Indeed, what is the advantage of Low voltage over 120 V wiring. It isn't cheaper. The risk of fire isn't reduced. Even 24 V or 30 V would be superior from a power-wire size point of view.
Doug
Doug
