TwoBlocked
- Bradford County, PA
- Industrial Electrician
Got a test coming up at my new job at a manufacturing plant. I LIKE conduit work, but don't say I am the best, especially with hand benders. I am more used to rigid using a machine. Anyhoo, been practicing and always seem to end up with the piece running a bit long using the exact measurements in the tables. I suspect why this happens and would like some feedback on my ideas, if you fine folks are interested. (I did some searching, but didn't find anything specific...)
The gain for a 90 degree bend is given as the radius multiplied by 0.43, yet when a piece is bent, the gain is more. I think there are two reasons. The radius is calculated at the midline of the conduit, and the midline stretches some. It's not like the inner part of the bend shrinks as much as the outer part stretches, leaving the midline the same length. So when bending a sample 90 deg and then measuring, don't we usually measure the outside bend dimensions? I do, and that is the way a stub is measured and bent - from the outside of the unbent part to the end of the bent part. So there is additional gain, half the diameter of the conduit, and any midline stretch.
Wouldn't there also be some gain due to midline stretch on 30 deg offsets? I know according to the tables it is negligible for 3/4" conduit , like 1/16" per bend on the center line. But with the midline stretching, and not merely "cutting the corner", it might be significant, maybe 1/8" per bend?
So if any are curious, one part of the test is to cut and thread 1/2" RMC to length and then hand bend a 90 deg stub and also an offset. The dimensions will be given at the beginning of the test. The tolerances are +/- 2 deg and +/- 1/4".
Not really worried about the test, although I want to do my best. So any tips would be appreciated.
