nojohnny101
New User
- North Carolina
- IT
First time poster on here. I have found the posts on here incredibly helpful so I thought I would ask a question regarding my current project to get feedback as I couldn't find much for searching.
the project: electrical sub panel for a shed. plan to have a 100amp subpanel being fed from a 200amp main panel in my garage.
I am running AL 2-2-2-4 about 350' feet through 2" gray conduit buried at minimum 18" deep. I already have the trench dug, conduit laid, but haven't pulled yet. That's because I'm trying to make sure I have a plan for the end connections.
My question: I have the 90 degree stubbed up out of the ground on the side of my house. What is the best way to go through the outside of my house to my main panel? The wall is an exterior one that is not insulated and is the garage. I have located the panel's location on the inside (inside the garage) and outside of the wall (exterior of the house).
I have read about two methods:
thanks everyone for the help!
- punch through the back of the main panel from the outside and connect (not ideal from I can see from my research)
- punch through the wall and then go up into the main panel from within the wall (I think this is preferred method).
- some questions if this is indeed the route that I should go:
- at what height should I go up the house before punching in?
- does someone have some guides for creating a clean hole (just a hole saw bit?) for the LB conduit box I have?
- does this mean I have to remove some drywall from side to help feed the wire up?
- once inside wall and going up to the main panel from the bottom, does it need to be in any more conduit?
