Sparky5150
How much of an issue is there for a CB if it sits idle in a NEMA 3R panel exposed to the elements?
I know these breakers operate without issue all the time outdoors, but I have a client that has many panels on site that have no load on them for long stretches at a time, then when he needs them most some breakers fail when they become energized.
Is it possible that the breakers build up moisture within while idle, then once energized the moisture causes them to short out/fail?
The breakers are standard 208 volt 400 and 200 amp 3 pole.
Thanks for any experience you guys can share.
