mickeyrench
- edison, n.j.
can someone tell me how to pressurize a enclosure to keep outside air out that is distroying componets inside? thanks
Mule , do we have to watch the pressure going in the enclosures? some enclosures are bibber than others. thanks again
This is outside of my area of expertise, but I have some qualms:
1) If the enclosure is not particularly gas tight, then you will have lots of gas flow needed to keep the enclosure purged. This can be very expensive in terms of the energy used to maintain the gas flow.
2) If the enclosure is gas tight aside from small leaks, then you have to be very careful about pressure control, using some sort of regulator. If you over-pressurize the enclosure, it could literally become a bomb.
How is this done when 'properly' engineered?
-Jon
Not sure what the contaminate is - but you might consider a vapor-phase inhibitor. Hoffman has it available.
http://www.hoffmanonline.com/produc...0&catID=80461&itemID=3433&searchFor=inhibitor
-Jon
