sfav8r
- San Francisco Bay Area
I am attempting to minimize the amount of time remodel estimates take. One task we do a lot is add receptacles to existing rooms, mostly with lathe and plaster. I am considering trying to minimize the estimating time on these jobs by having an average cost per receptacle/switch plus a cost to bring a circuit to the room as a separate item if needed. Have any of you come up with a better, easier, or more accurate way? I am also curious what you feel is a good average time per outlet. I am considering two models. One model would be for jobs where the basement is accessible and we can open the wall where the outlet goes and drill down to pull wire. The other is where there is access through the ceiling and we have to open up for fire blocks. I was originally thinking about 1 hour per outlet to cut the hole, open for the fire block and, drill through the top plate and pull the wire up. Then I would add a charge for a j-box in the attic and running power to it. I think the circuit charge will be impossible to place a "standard" time on because you never know where the panel wiil. be.
Any input or thoughts would be appreciated!
Thanks
Thanks
