sfav8r
- San Francisco Bay Area
I am bidding the following job:
Install 6 recessed lights in living room. Switch these off of the existing switch that currently controls an outlet.
Run an additional new switch to control an outlet which currently is not switched.
Install two "wall wash" recessed lights and add an additional switch next to the switch mentioned above.
Install 6 recessed lights in family room to be switched from existing switch. Remove existing lighting outlet.
Install 4 recessed lights in Kitchen to be switched from existing switch. Remove existing lighting outlet.
As a VERY ROUGH number, I use $100 per light for recessed lights. There are a lot of things that affect this, but it's seems to be as good of a a guide as anything else. That would come to $1,600 on this job.
My actual bid was $2,200 because the attic is full of blow-in coated newspaper insulation, is very tight and someone has installed planking over some areas where the recessed lights need to go.
I'm curious what some of you would charge (the labor is really the only thing that I'm curious about) The H/O says they got an estimate for $500 plus materials.
How can this be? There is no way that job is going to get done in one day. Just moving all that insulation around and finding the existing circuits is going to take a while, then how about running the switch legs down the walls and figuring out where the wire for the receptacle that needs to be switched are? It's not rocket science, but it takes time.
Am I over thinking this or is the bid about 70% too low?
