FDT
New member
- Exeter, Ca. USA
When installing a single phase transformer, primary is 480v, secondary is 120/240v, it's not quite clear to me as to the grounding issue. If I bring in a ground from the 480v supply, where do I terminate it in the transformer enclosure since I for sure have to ground the secondary and terminate it by use of a ground rod? I would not think that both termination points within the transformer enclosure would be the same since this will then create a ground loop between the new ground rod for the transformer and the ground rod from the tranformer primary feeder.
