I was at a job where utility allowed the electrician to use tape shielded cable on 12.7KV primary.The padmount was wired Y,Utility said if you ran a 1/0 along with tape shield It would be ok.(parralled conductors).My understanding is that you can not parr. two different type conductors and the tape shield is not ment to carry return neutral current.Will the tape shield termination be stressed from carrying current?
