metallica5
- Metro DC
I have one 13.8kv Delta pri x 4.16kv Wye Secondary 4000kva transformer and the second is 13.8kv Delta pri x 480/277 Wye secondary 2/2.6MVA.
Transformers are individually fed from an S&C metal clad switch gear. I am looking to size the fuse needed in the S&C gear feeding the primary side of each transformer.
Thank You
Thank You
