Re: Primary tap connections
You do not want to design you system that way! Use loop feed (6 bushing, 2 bushing for single phase) pad mounted transformers. If you have a cable fault from the tap to the transformer, you would be out of business. By using loop feed, it doesn't matter where a fault happened, the bad cable could be switched out and the whole system could be up and running again.
A loop feed transformer works by looping the primary, unfused, through from bushing to bushing. A bay-o-net fuse goes from the jumper to the primary coil and may be removed and replaced with a shotgun hot stick.
With a loop system, you need an open point and to feed the loop from both ends. You need lightning arresters on both ends of the open point. The MV cable needs to be large enough to handle the total load of the loop.
You need two qualified people to do any work on the system whenever any switching is done.
