Shockedby277v
- Michigan
Anyone ever use primer on underground electrical pvc??? Any objections??
Jim W in Tampa said:It might leave chemicals in it that could damage the wire.
mdshunk said:If you do use primer, do the sparkies of the world a favor and use clear primer. Purple primer on conduit screams out "a DIY hack was here".
Shockedby277v said:Usually I don't use it. I was asked to use it due to so much water.
celtic said:Awhile back -on this forum or another one - that same question came up.
I responded that plumbers use the primer (and of course glue) to keep water IN; electricans do the same to keep water OUT.
Then someone sank my battleship.... no matter what you do, water will accumulate in a pipe underground.
Primer is a solvent to clean the pipe and help the chemical reaction of glue and PVC (by having clean surfaces)
Shockedby277v said:define dringing ???
I did not hear thatShockedby277v said:LMAO!!! GAWD ... I can hear the inspector already.
curt swartz said:Jim, where did you get the information that primer is not permitted on potable (drinking) water lines? If you read the instruction from most solvent cement (PVC glue) manufacture they always recommend primers. The purpose of the primer is to clean and soften the pipe and fitting prior to the application of the cement.
I have never used primer on PVC electrical conduit and don?t believe Carlon indicates it is necessary.
Shockedby277v said:Do you think it would help keeping the actual water in the ground out though??
