donf
- Tidewater Virginia
Greetings,
My Niece has a problem with a branch circuit that is intermittently cutting out and dropping circuits in two bedrooms.
The branch circuit, originates at position 14 on the panel. It is a 20 amp circuit.
I tested the output of the breaker at the panelboard and it was reading 120 VAC.
The home run goes from the panelboard to the first of two lights in the upstairs hallway. At the second light, the circuit splits and feeds several circuits in the master bedroom and all of the circuits in the 2nd. bedroom.
Both lights in the hallway are on. Apparently they wired from the first light to the second light using 12/3. At the second light, the red conductor feed the bulb on the second light.
The black conductor then connects to a bundle of blacks, which at this point I am guessing is the junction for the other two bedrooms.
There is 120 VAC between the neutral at the second light and the bundle of black conductors.
Neither of the bedrooms show any voltage. The first device in the circuit in the second bedroom is a fan/light. The switch loop to and from the light circuit has been verified using an Ohm meter.
There is no voltage present in any of the rooms outlets.
The original failure was that at intermittent times, the circuit would just drop dead and both bedrooms would lose power for several hours and then the circuit would just reactivate.
I checked the entire circuit for loose Neutrals, but I did not find any.
I'm open for more suggestions, please.
