Problem lights dim
john p
I am hoping someone could give me a good reason for the lights to dim if the refrigerator or ac or microwave were to start, All the appliances have there own circuit. Thanks for any help. John
Re: Problem lights dim
I think i would check line voltage,at the pnl,make sure line 1 and 2 are not loose also check neutral if they are ok you might get the poco to check the meter base conections and the transformer at the pole
I was thinking in the same way, The last time i had this problem, It turned out the power company made a splice in the riser to the meter and we didn't find the lose connection until the pipe was melting.
Thanks for responding, I will go check for loose connections in the panel and meter. and if i don't find anything loose i will have the power company check at the transformer.
John
