flashlight
- NY, NY
- Electrician, semi-retired
We installed a door chime at the rear of a commercial space, to alert the employees when a customer enters.
The switching circuit is controlled by a NO magnetic contact on the front door, which energizes the circuit when the door is opened.
The problem is, when the door is held open, such as when they are loading
things in, the chime rings once, but the solenoid remains energized until the door is closed. While the door is open, the hum of the solenoid is audible, and I am concerned that the solenoid will burn out. The manager has complained about the sound of the solenoid.
What kind of chime or relay can I use to alleviate this problem ? They don't want something that sounds constantly while the door is open--just a single alert when the door is opened. I would appreciate any thoughts on this.
