- Tennessee NEC:2017
- Semi-Retired Electrician
I put in a Lutron wireless RF switch for a customer a couple of days ago. I will put a link to the switch below. I put it in a 2-gang box that contained another switch which was just a regular switch (might have been a 3-way, as I didn't notice). That left me with needing a 2-gang plate with Decora on one side and toggle on the other. I didn't have a plate with me and the customer said he would pick one up and put it on.
Now a few days later, he calls and said when he went to put the plate on the wireless switch was so hot he couldn't touch it. He took it loose and asked me to come back and check it. Since he's quite a distance away I want to only make one trip so I need to know if something is wrong in the wiring or in the switch itself. If the latter, I need to order a replacement. Anyway I just want to know what to look for when I get there.
Let me add that this switch doesn't require a neutral. I don't know if it uses the EGC or not. However, the house was wired before switches required an EGC. So there was no EGC in the box so the EGC from the switch isn't connected to anything.
So what could be making the switch get so hot?
ETA: The switch works about (4) 4' fluorescent lights
Here's a link to the switch. You can scroll down the page and find the PDF files for install and specs. If you're not familiar with the switch these files will explain. This switch is exactly the same as the Caseta.
https://www.1000bulbs.com/product/117305/LUT-PD5SDVWH.html
