SSDriver
- California
- Electrician
I'm currently having some issues with the Lutron switches. I have 3 switches (just the ON/OFF, not dimmable) and they bleed 10-11v in the off position. I checked them with a low impedance meter with NO load connected. I first noticed it when some CFL bulbs would flicker every 2-4 min while off. This reminds me, I need to contact lutron. In the room that has LED bulbs there is no noticeable defect unless you check it with a meter. If you touch the wire, you do get a little zap.
