If I run 6/2 MC with ground from the panel inside a residence and strip the armor and pull the thhn through EMT for an EV charger without splicing it in the box where the cable exits the basement into the garage, is it necessary to bond the 4 square box where the transition takes place? There would be no splices in the Box. The MC would be attached using a listed fitting. And a set screw EMT connector is used.
