webharvest
I have a sump basin in my backyard that is 25’ or more away from the side of my house. Right now the pump is on a dedicated GFCI breaker. The wire is buried underground and it is not in conduit over to the basin. The wire goes to a outlet box that is mounted to the side of the basin at the top on the inside. The GFCI breaker in the breaker panel was tripped and we got a lot of rain so I looked in the basin. The water was filled up to the top of the basin and the outlet box was submerged. I ran an extension cord to a GFCI outlet in my bathroom and the pump ran just fine. I’m thinking the buried wire must have insulation that is broken down since it has been in the ground for 26+ years. I’m not sure how to test to see if that is the real problem, is there a way to do that? I’m thinking I should just rerun the buried wire and put it in conduit but how should I handle the wiring of an outlet at the basin for the pump to plug into? I don’t think it is to code to have an outlet in the basin but maybe that is okay? The only thing I could think of is put a post next to the basin and mount an outlet to the post above grade since the wires on the pump are only 10’ long. That will be kind of a pain for mowing but seems safer. Thoughts or ideas? Also can I run regular NM-B wire underground as long as it is in pvc conduit or do I have to use UF-B even if it is in conduit?
Sorry for all the questions just want to make sure I do the job right
