I am an A/V contractor and would like to ensure that I am grounding my equipment racks correctly. In most cases, the equipment racks are not in close proximity to the main panel ground bar. So, I am unsure what the racks should be attached to in order to ensure proper grounding.
It appears that a common practice is simply to connect the rack to AC ground via a grounding screw on the rack's UPS. However, I am unsure if this is adequate.
So, on a new construction project where the A/V rack will not be adjacent to the main panel ground bar, exactly what should I ask the electrician to provide to ensure the rack is properly grounded? In other words, what is the correct wording of the grounding infrastructure that I should request, and what exactly is that infrastructure comprised of?
Much appreciate any thoughts.
