I have been searching the NEC and would like any input into grounding radio electronics (base stations and antenna systems). With new installs it is easy to spec a bus bar to tie to. In an older building, without a ground window/bus bar is it permissible to use existing electrical conduit? There is also a fire protection sprinkler stand pipe. Any help would be appreciated. If you know the specific section that would also be helpful.
Thanks
Thanks
