chevyx92
- VA BCH, VA
Here's the situation. An existing service feeds a strip mall. Poco feeds trough, taps are made in trough to feed each of the 6 meter bases. Below each meter base is a fused main disconnect. The trough is grounded by means of a cold water ground and a building steel ground. Some of the disconnects have a ground running from the trough, to the disconnect neutral bar, bonding it to the enclosure. The disconnects also have a ground running to a ground rod. Now, some of the disconnects have a separate cold water ground and building steel ground, as well as the ground rod. Shouldn't each disconnect have a separate cold water ground and building steel ground? Or is their installation of bringing the GEC to the trough, and then from there to the disconnect correct? What is the proper way this should be grounded? As some are grounded one way and others are grounded another way.
