J
jonny1982
Guest
I noticed some existing panels where phased from left to right (A,B,C) instead of from right to left (A,B,C) when I hooked up my rotation meter. The colors where also off (B phase correct being orange) but the other two (Brown and Yellow) flip flopped.
It got me thinking, is there actually a code that says panels must be phased a certain way?
With phase rotation, does phasing really matter unless working with motors? Like, if replacing a panel, I see how it is important to re install the new one just like the old one because if there are motor loads connected, they have all been running the correct rotation with the existing phasing in the panel.
But is it safe to say that if the phasing is off in a new panel that there isn't much to worry about (except a bit of confusion) because all new motor circuits will most likely be bump tested after install?
Thanks
Thanks
