Proper terminal when using stranded wire for ground tail?
bjp_ne_elec
Southern NH
I am doing a job and it calls for #12 THHN, and I was thinking of using #12 stranded for the ground tail in the boxes that I'm using to bond to the metal boxes. What's a good terminal to use on the end that will attach to the screw. I hate mixing those solid copper ground tails - as ideally, I like to keep everything stranded, as it makes it much nicer when you wire nut all stranded.
Thanks,
Brett
A forked sta-con:
[Panduit]
The yellow ones fit a #12 nicely.
I think someone makes a ground tail with a sta-con already attached?
Celtic - thanks! I was looking for a one piece solution, so if you think of who makes them, please post it. I'll see if any of the local supply houses have them.
Thanks
Dave
Whoa there partner...kb was a full 1/2 hour quicker on the draw.
But keep trying...I admire your determination ;)
