pfus
- Chicago NW burbs
- Elect. Engineer
I like to determine the best way to install a 12V driver for small recessed lights together with a dimmer or switch in a metal 2-gang box
So, one one side 110V line with switch and on other side driver wired to switch and neutral. Other side of driver is 12V which would leave box though a rubber bushing or so behind drywall. It seems that there should be a divider wall in between?
Kind of like this:
gekpower.com
as a wall mounted box with regular faceplate in front.
Something like this partition plate?
Or is this overkill? It seems a good idea to ensure that 12V wires can never touch 110V.
Kind of like this:
LP-ULTD-09003 Constant Current LED Junction Box Driver
Constant current dimmable LED drivers, Constant current driver, Model LP-ULTD-09003 Input Voltage 120V AC Input Current 0.025A Output Regulated Current 120mA Output Power 3W Output Voltage 25V DC
