Proper way to run 100A service from a meter through a building and then underground
Beanprofit
New User
Winooski VT
Hi,
I am building a garage with an apartment over it on my property. I am installing a dual meter socket so the apt will be metered separate. I need to run the power for the apartment from the meter 35ft through the basement of the existing house, out the other side of the house and then in a 85ft long underground conduit to the new building. It would be most convenient to run the same piece of URD cable from the meter through the house and then underground to the apartment. Is this possible? If not what is the correct way to do this?
Thanks for your help!
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
