360Youth
- Newport, NC
I actually saved that draft to my desktop months ago. I believe we are past the draft as everything has been finalized so I am not sure how far off the draft is from the real McCoy.
Hey if there aren't any changes then I won't need to buy the new code.
Thank you that is a useful link. I don't think there will be much out there yet for changes to the NFPA sprinkler codes since the next code cycle is 2013.
Here are two links fo International an NFPA codes.http://publicecodes.citation.com/icod/index.htm and
http://www.nfpa.org/aboutthecodes/list_of_codes_and_standards.asp
..........If there are no changes to the draft than I may not have to look into the cd-rom version of the 2011.........
There won't be one anyway.
Why is that? To easy to share?
May I suggest changing the scrolling speed in your mouse's software properties? I can change mouse properties for individual programs or globally with the one I have.A problem I seem to have with the pdf version of the codebooks is that my mouse scroll wheel becomes very sensitive with that file loaded.
Yeah, but you have to hold it outside your window at just the right angle, and at exactly the right time.Globally, that is cool, can you speed mine up? :grin:
Let me know when you're ready.
