powerplay
- In front of a computer.
I had a call to go connect an cable that was buried with the homeowner's permit to an tagged 200A meter base. There is an temporary panel there that needs to be removed off the pole, and the cable entered into the meter base in it's place that will feed an pumphouse panel, which in turn will branch off to feed an cottage and another shed. The cable is ACWU (aluminum 250 MCM for a voltage drop), and if not passing through concrete into the ground, is it necessary to sleeve it as it enters the ground on private property with some PVC to protect it from being sheared/damaged?
