Greg Wrenn
I have a forge machine that has heating probes that will heat up dies. Once in awhile the probes will go bad and because we have a 480 delta system with no neutral, the bad probe will create fluctuations in the voltages on the lines throughout the plant. This last round I had 400 plus volts on each of two lines to ground and another line with about 60 volts to ground. I was suggesting that we get an isolation transformer for that machine so that I could give it its own neutral. Is their another solution that might be cheaper but still at least keep the issue to that machine.
