electricraig
- nj usa
I have worked on a residential 200 amp service where i was contracted to replace the line side service entrance cable above the meter enclosure which was cracked & 200 amp panel . The load side se cable was existing & in good condition , hence I did not replace it ! The inspector came to inspect & told me I need to "sleeve" the existing load side se cable with pvc pipe where it passes thru the block foundation I asked why , he said the sheathing is subject to deterioration because it is in direct contact with the concrete patch, note this is modern se cable with an overall PVC sheathing.
