A alto3 Member Sep 19, 2006 #1 Hi, Can anyone tell me if I need to use MC cable to wire a kitchenette in a public library? It is a one story building in NJ, and the area will not be used by the public, only the employees will have access. Thank You
George Stolz Moderator Staff member Location Windsor, CO NEC: 2023 Occupation Hospital Master Electrician Sep 20, 2006 #2 You would probably need to find out what the building type is. Chances are, MC or EMT would be required. Don't forget to check out 210.8(B)(2).
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician (retired) Sep 20, 2006 #3 I agree with George. Once you know the building type then you can look at 334.10 to see if NM cable is permitted.
