Public meter/panel required?
Leespark57
Boston, MA, USA
Example is, service upgrade for an old 2 family home with a wide open basement and a small common entryway. I'm getting conflicting interpretations from inspectors on 210.25(B) and the requirement for a 3rd meter and public panel. Some say if the common area circuits are fed from the landlord's panel, no need for a common panel. However, these 2 families are all eventually turning into condos it doesn't seem relevant.
Any opinions would be appreciated.
To me, they're the same thing.
Now, if you're saying one of the two is the "landlord's" panel, and that will change and neither will be a landlord's panel, there needs to be a way to assure common areas will be supplied regardless of tenancy.
Usually, exterior and hallway lighting, as well as any shared spaces like basements, are considered common areas. I have seen dual-socket fixtures split-wired between units in shared hallways to provide this.
‘Is it owner occupied? I would give the home owner the option to do it but if they don’t care what the next owner may do I wouldn’t either.
