I am going over the scope of work and engineering requirements for a bid and have a few questions. The job is re-routing some existing underground lighting control and irrigation control in a park in Seattle.
"After final assembly is in place, all raceways shall be thoroughly cleaned and a mandrel, correctly sized for each size of conduit, shall be pulled through all raceways, prior to installing wires or pull cords. Mandreling shall be done in the presence of the engineer."
What suffices for a mandrel? Probably not a mouse...So...?
"Wire and cable pulling equipment shall be equiped with an accurate gauge to allow continuous monitoring of pulling tension.
Is this boilerplate language or is an engineer actually going to want a gauge on #12 copper? If so, any recommendations on a gauge?
"Measure the ohmic value of the electric service entrance metallic "system ground" with reference to "earth ground" using the "multiple ground rod" method and suitable instruments. Maximum res. to ground shall be less than 2 ohms. If this resistance is not obtained, then add additional ground rods and retest until the res. is below 2 ohms."
What would be a suitable instrument?
TIA for any ideas.
TIA for any ideas.
