frizbeedog
- Oregon
Does anyone know of a puck light that is 120V supplied that can be hardwired?
Most I've seen are plug in type.
I generally steer clear of these but wac lighting might have something nice.frizbeedog said:Does anyone know of a puck light that is 120V supplied that can be hardwired?
buckofdurham said:I think they get to hot for in the cabinet.
But back to your question. No , I,ve not seen any that are hard wired.
buckofdurham said:They make some nice LED in recessed lights now. High dollar ones.
stickboy1375 said:How about installing one of these on top of the cabinet. If the heights allow it. Check out the link for all the dimensions.
http://www.waclighting.com/USA/products/?categoryid=64&productid=845
Along with one of these,
http://www.waclighting.com/USA/products/?categoryid=67&productid=265
if cabinets r in ceiling, why not go for a small recessed light?frizbeedog said:I havn't either. Cabinet design got changed. Cabinets go all the way to the ceiling, almost, small space but crown molding already installed. No attic above this area, and cabinet dude drilled a hole in top of cabinet and poked the wires through. Bummer.
I was planning on switched receps above cabinet, but that's out.
I have to punt now. I might be looking at a small can light now.
cloudymacleod said:if cabinets r in ceiling, why not go for a small recessed light?
frizbeedog said:The lights I used are small. That was the whole point. :smile:
stickboy1375 said:Yep, A normal recess light in a cabinet would look terrible IMSO....
frizbeedog said:I've seen this a lot.
IMsuperiorO?
IMslackerO?
IMsleepyO?
IMsarcasticO?
IMstickboyO?
quogueelectric said:Hey dogboy I said check out wac lighting in the second post and then stickboy comes along and steals the show.
Well I ought to tie a shoestring to a wiffleball and tie it to your tail.
That ought to keep you busy for a little while.
"Oh I put them in and they are just perfect"
I will get you a spot on project runway for petes sake if thats the way you roll.
Id still like to wiffleball him just for good measure.stickboy1375 said:We did have a few PM messages if it makes you feel any better....![]()
quogueelectric said:Id still like to wiffleball him just for good measure.
OK I will sleep tonight without thinking "Thanks Stickboy for the lead. I will use these again."frizbeedog said:I consider myself wiffeballed and measured.
Thanks to you too quog.![]()
quogueelectric said:OK I will sleep tonight without thinking "Thanks Stickboy for the lead. I will use these again."
