I am pulling (12) #12 NM throug 2" rigid PVC 24" in length. Is there a requirment that I install a pull box bigger than 8" x 8" x 4"? These conductors are not larger than 6 AWG.
There may be another problem hiding in the details. Does your conduit originate at a panel ?
If so, can you describe the install (surface, flush, etc)
It's a surface mount outside. Yes, NM will be spliced into a j-box.
