Not sure what you asking need more informationWhat code article would I find where you can’t run Romex into a pull box with feeders and set a junction box and make a joint. 4 separate 200A feeders running thru this 24x24’’ j box- in which is sized to small
yes, can you have a pull box with feeders and also run NM cable in that pull box and make a joint on the NM? the pull box has 4-2in coming in and 4- 2in leaving also 3- 1 1/2''comimg in and out
